1.3 carb engine
1.3 carb engine, will be removed from a 1991 mk2 golf.
4+e gearbox and any other ancillaries included.
Good runner, small Water and oil leak, but nothing serious, haven't had to top up any fluids in 700 miles.
£200 Ono.
A477A02B-1C39-4388-BA8D-1C1B526814FB_zps
Can be seen running before it's removed.
Located in South Wales
  • Replies 11
They did not make carbed engines in 1991, SPI maybe?
In the golf they were carb engines until pretty much the mk3 (excluding Gti models)
No VW with cat was delivered without efi
Doesn't have a cat. And mk2 golf GTI (digifant)
Polos had cats and EFI, only top golfs had injection..
Mk2 golf 1.3 engine had a pierburg 2e3 carb. Hence the pancake air box :)
I've got a 90 1.3 mk2 polo with a cat....
I know the POLOS have EFI and catylitic converters from 1990 onwards. The GOLF did not get a catylitic converter till 1992 when they were mandatory. This engine is from a GOLF. bit odd adding a golf engine to club polo but it will fit into a polo 86c and would be a nice upgrade for a wheezy old 1.0 carb
splitting for spares.
carb/inlet - £40
air box - £10
5 speed gearbox and everything to convert your 4 speed - £60
alternator - £15
starter motor - £15
distributor/newish coil (vac advance) - £30
water flange on side of head (w/ all pipes) £20
2 speed rad fan (and rad) £10
full exhaust system (new center) £10
engine block (could split head and bottom end if i really had too) £30
all prices are collected. could do postage on smaller items for an extra charge.
Carbs gone. But the vac advance dizzy is still there...
How much for one piston posted to north east england?
I believe it to be a slightly different engine code. Come to South Wales and get the head and bottom end for £30! Still in the car. Was running a few hours ago until I removed the carb and dizzy for postage..
