G40 part numbers
G40 part numbers
Head gasket 030 103 383R
Camshaft oil seal 030 103 085A
Thermostat housing 030 121 117M
Thermostat 030 121 113
Blue temp sensor 045 906 041A
Manifold gaskets 030 129 717D / 030 253 039 A
Oil filter 030 115 561AB
Rotor arm 052 905 225C
Dizzy cap 051 905 207
Timing Belt 030 109 119A
Water pump 030 121 005LX
Throttle body gasket 030 133 073A
BRV gasket 030 133 074
Dizzy oil seal 030 905 224
Fuel filter 1HO 201 511A
Head bolts 030 103 384
Thermostat bolts N61 033 073A
Sunroof slides 443 877 681D / 443 877 682D
Thermostat temp seals N 903 168 02
Boost air sensor O ring
Calliper bolts N 044 755 3
Retaining spring for air 032 121 142
Sensor on boost pipe
2 part numbers for the waterpumps are as follows.
052121005AX this one is the one with larger gaps in the teeth
052121005LX and this is the other one.
I will add more soon. i just haven't got the packets with me for some of them.
  • Replies 64
  • Views 28.4k
While your building up a parts list on here your not working on your car.
You should have the complection a Goth would be proud of from working in a dark workshop, however you are brown and tanned from walking back and forth to the Mill VW dealers for bits without a car. Tell you what, if you run to the mill and back every day after they have had their delivery you will get fit and have more time building the car ........ come on dude buck your ideas up and build the car instead of talking about it.!
its almost done. give me a break. :lol:
Pined by me. Very usefull indeed.
Rocker gasket 030 103 483C £17.01
Cam pulley bolt N 902 562 02 £0.39
Cam pulley washer 027 109 143 £2.82
Charger oil feed banjo bolt N 901 836 03 £1.13
Rocker bolt 030 103 531 £10.22
Crank case breather 030 103 129 £20.87
Charger oil feed banjo bolt washer N 013 830 2 £0.05
here you go chaps
Oh by the way those prices I provided are before VAT, sorry.
Camshaft oil seal £13.33
TB gasket £1.50
Downpipe gasket 871 253 115 A £9.36
Downpipe nut N 102 090 05 £0.27
Black temp sender 251 919 501 D £17.64
Front/rear bumper bolts 867 807 199 £0.80
Front bumper grille bolt N 010 218 6 £0.30
Wing washer N 011 666 15 £0.16
Wing bolt N 015 946 1 £0.29
Headlight screw N 013 969 4 £0.15
Rear axle handbrake support/bracket 867 609 757 £4.85
Rear axle handbrake support/bracket bolt N 010 242 22 £0.32
I know these are MK3 generic but I thought they maybe of use to someone.
here are some part numbers and there vag parts price that i have had:
Note: All plus vat @17.5%
G40 engine bits
N 044 410 4 exhaust studs £0.26 each x5
N 900 850 01 exhaust manifold - block nut £0.14 each x5
N 011 558 11 washer for above£0.05 x5
861 253 209 suport plate for downpipe (just before cat) £1.14 each x2
030 109 119 A timing belt G40 £7.20 x1
030 109 127 D timing belt lower cover £7.84 x1
Gaskets -
030 129 717 D inlet £3.85 x1
030 253 039 A outlet £3.89 each x1
030 133 073 A throttle body £1.22 x1
030 145 119 supercharger O ring £2.08 x1
030 121 119 thermostat housing to block £0.64 x1
N 014 705 3 nuts for throttle body to manifold £0.08 each x4
N 012 226 5 washers for above £0.04 each x4
871 145 851 fan guard cowel ladefult gechult £13.30 x1
N 010 218 6 nut for above £0.14 each x2
N 011 557 2 washer for above £0.04 each x2
443 857 113 A glove box door lock - £9.46 x1
Oil T piece of G40
N 013 811 5 sealing washer £0.04 x2
035 103 715 banto bolt £8.62 x1
N 013 818 2 sealing washer £0.10 x1
030 103 717 adaptor £11.39 x1
N 013 808 5 sealing washer £0.05 x1
Headlamp washers
867 955101B Headlamp Washer unit £27.25 x1
867 955102B Headlamp Washer unit £27.25 x1
N 011 5476 securing washer £0.37 x4
N 011 00624 securing nut £0.23 x4
281 955187 “T” piece for Headlamp Washer £3.46 x1
867 955 453 C Washer bottle (7.5L) £19.99 x1
191 955 980 Pipe Clip £2.47 x1
GT squareback (hearse shape) bumpers. Front with fog holes please.
GT/G40 graphite With Fogs* - 867 807 217F 2BC - £102.04 x1
GT, Graphite (hatch)* - 867 807 417C 2BC - £114.28 x1
*Both with the red trim insert please.
G40 engine bits
N101 638 01 Radiator bolts (x2)
030 141 031 GX 3 piece clutch kit (x1)
N 903 207 01 Clutch retaining bolts (x6)
871 399 301 A Gearbox mount (x1)
N 900 717 02 manifold to downpipe stud (x4)
wiper arms
868 955 407 B front complete (x2)
867 955 706 B rear complete (for hearse shape) (x1)
Wing mirrors
867 857 543 base plate left (x1)
867 857 544 base plate right (x1)
N 014 133 5 securing screw (x4)
rear axle bits
N 102 090 05 (x2) bush nuts
N 011 527 11 (x4) washers for above
N 901 300 01 (x2) bolts for above
861 505 229 A (x6) axle to body bolts
861 513 471 (x2) rear shocker to axle bolts
Chassis support plate fixings (just after cat)
311 199 125 (x4) washers
N 010 240 22 (x4) bolts
Edited by genesisGT
Shouldn't these all be sorted into one big list?
Seperated by sections
yes that would be ideal
you wanna do it del?
  • 3 months later...
I think I might do it and add some of my own to it as well. Got part numbers for gear knobs and such like.
Does anyone have the part number for a vag de-cat for a g40?
Vag part number for the G40/GT cat bypass is 871253091D - pay VAG £111 for the pleasure - or go to eurocarparts and type in the search box 701440731 and pay £18.10 + vat for a reproduction one! :)
wouldn't be so sure about that - it comes up with early gt ones etc - the bores on a g40 downpipe are much larger that any other mk2 or 3 i've seen, as is the downpipe gasket...
GT & G40 gasket part numbers are the same! :) (on the euro car parts catalogue)
Asked Pitstop - they said they are different! Ignore the above info!
Proper G40 Head Gasket as above,
Metal (slightly thinner) Head Gasket (from psd forum) VAG 030 103 383 AH - or - GSF: 11133B
hope this helps someone, spent ages looking for it!!
Do you have the numbers for the bolts and what car its off too?
'97 vento, 1.4/1.6 apparently, engines AEX/AEE/AEA/APQ
headbolts, same as any polo. (they are 1mm shorter than proper g40 ones, but this doesnt matter apparently)
so vag 050-103-384 (with washer) 11mm. - or - GSF 01161
someone correct me if I'm wrong
Fuel pump - 867 906 091
distributor (whole thing) same as GT
030 905 205 P (original)
030 905 205 T (this one superseeds above 'p')
if anybody is having trouble getting bosch w5dpo's the vag part number is 101000006ag they are £10.22 + V.A.T. they are longlife plugs so will last for 30,000 miles.
http://www.vagcat.com/
You have to register but its free, very usefull, get all the part numbers you need, this list is a great idea though.
