G40 part numbers
does anyone have the part number for a coilpack?
  • Replies 64
  • Views 28.4k
from etka
3pin transformer & backplate 6N0 905 104 = engine: PY,AAU,AAV,3F
6pin backplate version of above = 701 905 104 A = ENGINE: NZ, hz, 2g, acm
gsf 3 pin polo coils
part name
92525 IGN.COIL/TRANSFORMER-3PIN PO 10/90 > £32.50
92525A IGN COIL/TRANSFORMER-3PIN PO 10/90 > £42.50
+vat
not sure on differences between them. sure someone at gsf will tell you
Edited by rae
  • 3 months later...
Long shot but part number for a starter motor for a G40?
And can anyone confirm a part number for dizzy cap for G40 to as the number in the thread did not show for a py lump at the dealers.
Cheers,
Matt.
Cheers,
Matt.
starters are apparently all the same, except diesel model
you have a choice of manufacturers though
part number // description // original part number
031 911 023 A = bosch (DIESEL ONLY) = #031 911 023 AX
036 911 023 K = marelli = #036 911 023 HX
036 911 023 M = Bosch = 036 911 023 MX
036 911 023 N = Hitachi = 036 911 023 MX
036 911 023 G = Bosch = 036 911 023 MX or #036 911 023HX
dizzy caps, it lists:
b 030 905 207 - earlier dizzys (ALL polos, including G40) [>>80-M-100000]
b 051 905 207 - later dizzys (ALL polos, including G40) [80-M-100001>>]
edit: i didnt think the dizzy cap mattered between the models.... but dont hold me to that
dont know why dealer couldnt find it, its all on etka.
does that help?
Edited by rae
Anybody have the part no. for the charger belts??
cheers
charger belt = "b 030 145 933 A" (times two obviously)
thanks rae
dont suppose you know the price of these??
cheers
cheers
vagcat says
8X1015MM / G40
030145933A / KEILRIEMEN / €14.8
but dont know what vw would charge here in the uk with vat,currency conversions and general uk tax. lol
Edited by rae
cam belt for G40?
cam belt for G40?
its shown twice on the first page of this thread
= 030 109 119 A - timing belt - G40
gsf: 13106 TIMING BELT-ROUND TEETH PO 1.3 10/90>7/94 (Eng. PY002178> 2G262740> 3F008527>) £6.40 +vat
all but the mk2 g40s etc... but there isnt any/many original ones in the country (ie engine code is less than 2178)
Edited by rae
867 906 091 What is this??
spark plugs for a G
Has anyone got the numbers for standard G40 piston rings, had a look on eurocarparts and gsf but they dont seem to list them?
g40 (py) ring set is same as HZ,NZ,2G,AAV,ACM.
etka tells me that they are different to the gt (3f) and AAU, also different to 1W (Diesel)
i found out from the piston ring manufacturers and from tecdoc that the ones that gsf sell (Thompson TH83213-STD (GSF # 16534)) were the ones recommended for the G40 as well as all the other petrol models
have fitted these gsf ones and got no problems.....
Cheers mate. Dont suppose you know if GSF stock; big end shells, mains and thrust bearings for the G40? GSF part numbers would be mint if they do!
16152 = Crankshaft main bearing shells (YOULL NEED TWO SETS, and use the halves that have oil holes only. you'l then be left with a full set that doesnt have any holes too) cheaper than VW ... again, found this out from the manufacturers. = 2x £121.60 + vat cheaper than vw... definately
16185 = conrod shells £8.75 for set + vat
if youve got it apart, consider replacing the gudgeon pin circlips (vw only) for peace of mind that one wont snap anytime soon & break your engine
16164A = thrust bearing £6.50+vat
can anyone tell me the part number for the metal water pipe that runs along the back of the block on a g40 and also the gasket if it has one
thanks
luke
Edited by ahh claudia
thanks
luke
is the pipe held on by 2 bolts? if so -
gasket = * 052 121 091 A (less than £1)
etka lists two rubber rings... only for the push on connections though
n 902 600 01 (36,2x3 - up to vin 80-NW240 000 / 80-MP080 000 / 80-NY170 000)
n 905 197 01 (32x3,55 - from the above vins)
mine was a bolt on pipe, and the gasket is from a mk2 polo - perfect fit.
the pipe is a tricky one
screw on = 030 121 065 D for earlier cars (see above vins)
push on = 030 121 065 Q for later cars...
i know this doesnt make much sence, but neither does etka!
rae
Edited by rae
nice 1 cheers
it does slighly confuse me but now i have the numbers i can check them when i go to vw
thanks
luke
G40 ecu??
there seems to be a couple of different part numbers for the 'py' engine code ecu's. I think it is based on cat models and non cat ones..
030 906 022 B - Electronic control unit
030 906 022 C - Electronic control unit for vehicles with regulated catalyst
030 977 022 TX
if you're replacing your ecu, the part number is written clearly on the top of your existing one...
