VWII calipers , reconditioned plus hoses
I have a set of vwII calipers. These are made by be BENDIX
I have stripped them down, cleaned the rust off them with a wire wheel and painted them in a textured gold metal paint to look a bit more oem then red etc and then lacquered. I then fit new seals to them. Very tidy looking and will work for a long time to come.
Also supplied are 2 sets of used hoses. One set is from a 6n and are shorter, the other are from a corrado g60 and are longer. May be of use even if you just wanted to see which is better fitting. I can provide the part number or ebay number for the new ones if needed.
Looking for £35 posted.
I'm located in kent tn29 postcode if you wanted to pick up.
Pics to follow.
  • Views 261
Il take them of your hands please. Il pm u my address etc
Second dibs, could collect with engine if that's still available
