Polo Open Air Breaking 1.4 8v
My little silver Polo will be broken at the end on the month so if you want anything let me know as I will break it and put to the side
Was for sale but the sale gremlin got to her the exhaust had a blow which was the clamp so repaired it but now the CAT has failed and collapsed and I don't have the time and money to fix.
8 new tappets fitted at 65000 miles,
New Oil separator (Oil Breather),
Sump cleaned and resealed,
Oil pick up cleaned,
Head gasket, valve stems oil seal, valves ground removed carbon build up and timing belt done at 75000. Due to valve stem oil seals being dry and crack,
Rear brake pipes change for MOT 2012 (copper and rubber)
New Windscreen fitted last year, MOT 2012 sush a difference with no scratches.
New Sachs Clutch fitted (27/07/13) See picture
New Fly wheel, fitted (27/07/13)
New Bearing Sleeve (2707/13)
New Starter bush (27/07/13)
New back box fitted last year,
New thermostat housing and thermostat 2012
New Temp sensor 2012
Rear arches are in good condition I treated it with krust to help stave off the dreaded rust.
Roof in good condition one small mark rear of roof where the roof creases at the rear when fully open
MOT:
19/04/2013 83779
24/04/2012 79540
29/04/2011 65512 I owned the car from this MOT
31/03/2010 60296
Bad points:
Bad points:
Small rust blister on drivers door skin. See picture
Small dent in bonnet,
Slight rust under fog lights,
Few car park scratches and stone chips,
The starter motor is a little noisy, was thought to be a damage fly wheel on inspection starter bush inside gearbox had broken, was removed and new bush fitted. Starter slightly noisy because of the bush being broken, car starts fine, read worse than it sounds.
Rear bumper has markers from previous owner unloading push chairs from boot,
Dent in rear valance near exhaust (from previous owner)
Trim under front light has broken clip on passenger side,
Front fogs light fitted by previous owner but never wired in.
Passenger door spline broken but on order and will be fixed before sale.
Collection only for large items can arrange post for smaller items postage to be added.
Engine £100 with gearbox included loom throttle
Wings £20 Each
Bonnet £15
Roof £100
Boot £20
Seats £50
Bumpers £10 each
Lights £10 Each Rear or Front
Indicators £5
Electric Switches £Cheap
Plastic trims bit £Cheap Varies on size
For other items please PM
Edited by residentmelon
  • Replies 11
  • Views 1.5k
pm'd
How much for the openair motor? Cheers
How much for rear wiper arm posted?
Literally just want the arm, as mine's snapped.
Hi mate how much for the n/s rear mud flap Posted? What condition is it in? Can you post a pic. Cheers
I have someone interested in the whole roof including motor if it falls through I let you know
£5 including postage
I get you a picture soon as I think they are a little rough at the bottom but could be trimmed off. once your happy I give you a price.
Ideal, I'll send you a pm
Did you ever get my pm buddy?
Yes I did
I'm struggling to get the car down to the unit to break but I get the wiper off tonight for you
Yes I did
No worries man, I'm in no huge rush. The one I have is holding up for the meantime.
PM me your PayPal details at your leisure bud and we'll get it sorted. :)
