Mk2f no interior heating?.....
So basically I've got no heat coming through to the cabin. I've checked the cable is operating the heater valve thingy, all good, changed temp sensor as dash water temp only just climbs above 70 degrees, no joy, still sits very low, so guessing it's the thermostat stuck open, keepingn engine temp down or a blocked/clogged up heater matrix?
Any ideas?
  • Views 729
  • darknights
    darknights
    Solved I think. New thermostat and coolant seems to have given me some heat :-)
If you have any other issues remember there is a little bleed valve on the heater matrix thing under the scuttle tray.
At risk of asking the obvious - you're not expecting it from the vents at the end of the dashboard are you, as these are cold air only and are not connected to the heater box.
That's useful to know. I'll check that out :-)
Surely the main vents at end of dash supply warm air? (The one on the right of this pic, I'm sure my last mk2f had hot air through these?)
The little top vent will put out warm air but the big main one is cold air only.
never knew that! cool cheers for the info :-)
