PoLo 6n and 6n2 and others parts for sale..
6n2...
o/s/f drivers door silver (bare)£10
o/s/r drivers door (complete ) £15
5 dr door glass £5ea
ecu 1.4 16v aua code £10
clocks £20
pedal box (repaired,v.strong £20
14" steel wheels 185/55 tyres £10ea
abs pump £20
starter motor £20
wiring panel off top of battery £5
drivers door loom 5Dr £10
o/s &n/s door mechanism lock mechanism £10ea
front headlamps (need buff ) £10 ea
drivers airbag £10
washer bottle £4
outer bumper grilles (lower) from se model £10 pr
book pack £5
airbag module £5
drivers air vent £5
central locking pump £15
front and rear seat belts £20 the lot
grey front door tweeters £10 pr
bonnet pull £3
1.4 16v engine cover/trim £5
interior mirror £2
interior door handles 2 x drivers 1 x passenger chrome £5ea
ignition cowling £10
front slam panel £20
spare wheel toolkit holder £10
POLO 6N
hazard switch £2
1.3 adx manifold heat shield £3
dash blanks £1
exhaust rubbers and brackets £1ea
door lock mechanisms £5 ea
n/s/r light lense £3
n/s/f indicator lense £2
drivers glovebox, dark grey £10
Various other polo....
GT steel wheel bramnd new, no tyre £10
14" 9n sao paolo alloy wheel with good tyre 5 x 100 £20
14" steel wheel 5 x 100 with avon tyre £10
17mm aluminium wheel brace gen vag £5
84 dgree thermostat new £2
spi throttle body, think its off a 1.8... £20
early mk4 golf non hydraulic gearbox, duw code ... ok for conversions ? £50
all parts are in south Manchester collection preferred, but will post small items at buyers expense.
contact me on here or text me on 07565360053.
also got a few b5 Passat, skoda fabia and golf mk3&4 parts....losing storage so need the space..
  • Replies 16
  • Views 864
also got 2 x cable gear linkages, one from a 6n2 the other from a fabia.
Hi you wouldent happen to have a mk4 golf wiper stalk would you?
Hi,I'm sure i have somewhere, ill get back to you..
sorry cant place the wiper stalk...
everything else still available.
Hi have you got a linkage for a 6n 16v ? Thanks
What code is the starter motor for? and what do you mean by book pack?
I've got the cable type linkage for a 6n2 1.4 16v.
the starter motor is for an AUA code, and the book pack is the wallet you get withn all the car info in it mnus the service schedule,
£20 posted for the starter?
If so, I'll take it.
How much for the linkage pal I'm in cheadle
Is the 6n left side indicator lense still available and if so will you post?
hi,the linkage is £20...
the indicator is still available. will post
sorry cant do starter for £20 posted.
Interested in the 6n2 outer grills. Do they come with the fog lights?
How much Is starter posted?
jackflory, the grilles are non foglight.
the starter will be around a tenner to post I should think.
still got lots for sale.... but neglected the post due to not being able to get on here....sorted now....thanks
You mean automatic gearbox? Do you still have it?
