Help on buying a 6n
Hi all
I`m a new member on this forum. I`m after some advice on purchasing a 6n, there`s a few things id like to know before I go and buy one and it turns out to be a heap!.
First of all, i`m only 19 currently driving a punto which does the job to get from a to b but id like something I could tinker about with, upgrade with sensible mods, and gain some mechanical knowledge.
I have decided on the 6n. cheap to buy, look ok etc etc. I`m getting my money together atm and planning on getting one in the next few weeks but I`m wondering - when I do go to look at one are there any common faults on this model I should be looking out for? Areas prone to rot, known mechanical or electrical faults, etc.
Also, could anyone recommend the best wheel and tyre size for when I get it uprated/lowered suspension, id like it to look nice but still have a bit of clearance for practicality
hope you guys can help
Tom
  • Views 486
Welcome to the forum :)
The 6n Polo is getting to an age now where every one will be different. So if you're not too sure on cars yourself then you're best to take someone with you who is.
The main thing to look out for on a 6n is rust. They are bad for rust pretty much everywhere. But have a good check over the arches and sills. Don't be afraid to have a good poke about at them. Also get under the car and have a look at the floorpan too.
Mechanically, first check the service history. If regular oil changes haven't been done then you could have an issue with noisy tappets. Also on the test drive check the car goes into every gear and there and no whining noises from the gearbox. If it's starting to go you'll mainly start to hear a whine when you lift off the throttle. Check the oil filler cap for a thick build up of 'mayonnaise'.
Everything else is just what you'd check with any car. Push every button and switch make sure it all works. Listen for any abnormal rattles and bangs etc. on the test drive. If you have access to one, take a VAG code reader or VAGCOM/VCDS with you and check the codes. Even if there are no lights on the dash there could still be old fault codes stored on the ECU.
Edited by kwijibo_coupe
Forgot about the whole VAGCOM thing.
On the 6N the engine codes are not OBD2 they are VW specific 4 or 5 digit codes, so you'll need either Vagcom/VCDS or similar
