Mk2f bumper stripe trim
I was just wondering where the best place is to buy the red bumper stripe that people put in the strip bit on there mk2f bumpers as I bought some from halfords which was 6mm wide and it wouldn't stick at all it just kept falling off!
  • Views 776
No matter what you but you'll need to make sure the area is both clean and free from grease. If you've 'back to blacked' your bumpers recently, this will also prevent the tape sticking so you may need to use a car polish remover on the area.
3M backed stuff is pretty good, so look for that
i ended up glueing on the carbon fibre effect strip i had which held well..... till i got the car pressure washed and that was the end of that!
Bit of kitchen roll, some methylated spirit and wipe the recess through a couple of times, should stick well then.
