Polo 6n Rebuild/restore (Fully smoothed engine bay)
Right, so I've given myself a project for this spring, and it's to fully rebuild/restore my polo 6N and reveal it on May 24th at Unphased15, I know this is an incredibly close deadline, but I'm determined and will try my best!
To do:
Pre rebuild;
  • Fully strip car to rolling shell (Inside & out)
Engine bay;
  • Clean/grind engine bay
  • Panel up, cut and weld engine bay - IN PROGRESS
  • Fibreglass/filler engine bay
  • Primer engine bay
  • Spray engine bay (White)
  • Extend & hide wiring loom inside chassis legs
Body;
  • Weld/fill side repeaters (wings)
  • Weld/fill aerial hole
  • Weld/smooth wings into sills
  • Install 6N2 boot
  • Install MK5 Golf boot badge/handle
  • Smooth left & right grilles on 16v front bumper
  • Smooth numberplate recess on 16v Front bumper
  • Prep body for spray
  • Spray body
Interior; (If I have time)
  • Dye/replace carpet (Black)
  • Custom made 6N white leather & carbon fibre dashboard
  • Custom made Carbon fiber trim (Including entire center console)
  • Custom upholstered white full leather Audi A4 B5 seats (Modified runners super low stance)
  • Custom white leather & carbon fiber door cards
  • Re-upholstered roof liner (VW logos)
  • Rear seats removed
  • Deck & carpet out boot and rear seat area
  • Build/install sub, speaker and amp enclosures
  • Build double battery enclosure in spare wheel well
Audio/wiring;
  • Run power wires from engine bay to boot for batteries (Through chassis legs)
  • Install sub, speakers & Amps
Running Gear;
  • Remove subframe & Suspension (Pre engine bay prep/spray)
  • Re-Install subframe & Suspension (Post engine bay prep/spray)
  • Install rear disk conversion kit
  • Install coilovers (Loooooow)
  • Install camber shims (1.5 degrees)
  • Re-install engine/gearbox/master cylinder
  • Install vr6 radiator with in-line filler.
  • Relocate washer bottle to boot
Optional;
  • Install smoke screen (Just for a laugh)
So there we go, I'll post photos and cross out what I've done.
;);) ;) See you guys in May ;);) ;)
Edited by ScottyLister
  • Replies 51
  • Views 14.2k
  • Was hoping to see it there :(
  • ScottyLister
    ScottyLister
    Getting the engine bay 100% finshed is the main priority. I can just throw the interior back in, stick it on its arse then rat it if needs be! Then get the body finished for Fitted Show! In July
  • Graffiti can paint it rather than rat look it,
All the cleaning and grinding I did last week in preperation for welding and smoothing!
All the plating and welding I did on 23/03/15.
I'm quite happy with the work I've done, it's all smoothed out now too, but my phone died later on in the day so I couldn't get a photo :/
11077899_873287742736984_100754381_n_zps
11074697_873287729403652_766430899_n_zps
11079122_873287712736987_630175077_n_zps
11082747_873287699403655_1831368390_n_zp
11079295_873287679403657_1327815459_n_zp
11073715_873287669403658_281296089_n_zps
11076839_873287649403660_620819918_n_zps
11077850_873287626070329_196441866_n_zps
11072669_873287612736997_1130916925_n_zp
11076140_873287586070333_650814233_n_zps
11080108_873287562737002_1088301089_n_zp
11086057_873287552737003_343095322_n_zps
11082676_873287546070337_344733404_n_zps
11079112_873287532737005_1538681878_n_zp
11079669_873287519403673_373304998_n_zps
A couple of better photos from the 23rd and some from last night.
I've now got the curved piece of sheet metal that goes from the mount to the wing welded in. I've grinded most of the welds out, but as you can see I've still got one more to do! :)
Good luck. You haven't got long but lets hope it goes well.
Thanks mate, yeah I'm running a pretty tight schedule. But as long as I get this engine bay fully welded by April, I should have a good chance of getting it all done! :)
Possible colour combo.
Chodosh blue body, red banded steels with baby moons, white engine bay & firewall and a while leather interior ;)
Looking nice , anymore pics?
Edited by taylor d
Looks good man, good work there.
Been down the unit again today.
Drivers side is all panelled and welded, just a little bit of grinding to do before I get some filler on it!!
Also got a pretty good start on the passenger side.
I never managed to get any taken tonight as I forgot my camera, I'm in the unit all day tomorrow (02-04-15) So I'll get some then and upload them for you :D
Thanks man, much appreciated!
Here's the photos, as promised :D Although there's still a lot of grinding to do!
Nice , looking forward to seen this wen done
Managed to get all of the N/S engine mount welded up today, and It's looking beautiful! Will upload photos tomorrow :)
Well the polo has been pretty neglected for the past two weeks... Ran out of MIG gas and haven't got around to getting any more, but I will tomorrow and get cracked back into it!
Unphased is looking a little out of the question now as well, much to do, not enough time!
Na don't rush it , take Time and do it right
Okay! So after a bit of thinking, I've decided to go down a different route with the bodywork, but I plan on keeping it a secret for now. All I can say is that it will be like nothing you've ever seen before! :D
If its rat look stop now.
Seconded, this has potential!
Please do not rat look it , Rat look is for old old vws not polos they look wank
Edited by taylor d
WW2 Messerschmitt colours. NATO green body, yellow banded steels with baby moons, emblems on the sides and bomber seats.
What're your thoughts?
Are those your plans for a kubelwagen you're doing up, sounds good.
If it's for the polo just leave the standard paint and polish it up. Really hate rat look on modern cars. It would be a shame as well considering the amazing work you've done on the engine bay.
But it is your car so do what you want. I just think you've clearly got excellent skills which shouldn't be wasted rat looking a car.
Edited by vdoubleu
I have to agree with wots said above ,
The wagon is an old Volvo Amazon :)
I'm really unsure. Tight budget and not much time
The original paint is knackered, sills need welded and there's deep scratches on every panel.
