G40 TCAs
Right I'm a little confused. After spending some hours reading up on TCAs it seems the rose jointed ones are the best bet when using the ARB blocks.
My only question is what if the inner (rose jointed) bush needs to be replaced? I can't seem to find any replacements...
The ARB has to be moved forward for the conversion I'm doing.
Cheers guys
  • Views 560
arb blocks work with standard arms too
when the joint is worn out then its up to you find an engineering shop to replace it , I'm not aware of any off the shelf replacement joints
