HELPPPPP :/
need to get this 98 polo started!!
we've changed everything ignitionwide and its still not starting....(distributor,distributor cap,arm, ignition coil, spark plugs, ht leads...)
Got the AA to come out and look and the tit said it was the distributor.. spent £200 on different parts and still no luck...grrrrrrrrrr.
anyone got any ideas?
its turning over just not starting.. tried to jump it, bump it, car says no.
  • Views 643
When you turn the ignition two clicks, can you hear the fuel pump prime under the back right of the car?
I'll go and have a listen! :)
