Mk2 ignition amplifier
As title says...
Late mk2 ignition amplifier and the bit of the loom too :)
  • Views 330
If you're stuck, I think gsf do the amp in their ebay shop for not a lot. The connections are standard spade connector size.
I've got the amp but no loom unfortunately. You could make up the loom yourself if you can't find one. Its only 4 wires :smile:
Cheers dude much appreciated, how much would you like for it? I think I may still have the lookout need to check
