Rocker removal
Has anyone got any ideas on how to go about removing the rocker cover from an AUD engine ? Thanks
  • Views 541
The rocker cover is also the upper half of the camshaft bearing, so to remove it you need to first remove the timing belt, with that removed you can then safely remove the rocker cover, the AUD is a stupid design not one of VW's best ideas :(
Ni
Do you have to remove the cam pulley aswell or just the belt ?
