Removing windows
6N 3 door.
What's best way to remove windows please.
Do you just prize it open around the rubber seals?
Replacing with polycarb windows. Cheers.
  • Views 686
  • steveo3002
    steveo3002
    they're bonded in , you need to cut the glue /sealer ,most folk poke some thin wire through and use a handle on each of the wire to use it like a saw , theres proper wire available but mig wir
  • Have a look at this http://www.clubpolo.co.uk/forum/index.php?showtopic=332230 it's for the 6N2 but exactly the same as the 6N
they're bonded in , you need to cut the glue /sealer ,most folk poke some thin wire through and use a handle on each of the wire to use it like a saw , theres proper wire available but mig wire works too
