fixing door locks
Both my doors have started playing up, I can use the key to lock and unlock from the outside. Yet only open the door from the inside. I'm not sure if this means I need to replace the lock itself or if I can just buy a new handle. Any help is appreciated.
  • Views 721
Popular Days
Presuming it's the polo you have written on the left there i'd suggest taking the door card off first and having a good nose around. You might find somethings just disconnected or the exact part that's broken that could be sourced from a scrapyard or somewhere and save a bit of money. Start at the door latch from the inside and look for what should connect to the door hande pretty much. Hope that helps.
