High Spec G40 breaking
Sadly the time has come for to me part with my Polo due to lack of time/effort to trailer it to and from track days plus I have a Lotus Elise itch I want to scratch and I cant justify having 2 impractical cars.
The car is in a running state so before I start breaking it I would like to have a buyer for the engine before taking parts off as I would like to ensure that the buyer can see and hear the engine running if required.
If you are interested in a part or parts then please contact me via email robinyau at yahoo dot co dot uk or pm me I will put your name down for the item and once I start breaking the car I will be in touch.
Prices are all excluding postage please contact me for prices.
All parts located in Crewe, Cheshire.
I am also willing to listen to offers for parts and would do a deal on multiple items.
Pictures of individual items on request.
If there is something you are looking for which is not listed please ask as I have loads of spares I have gathered over the years.
Build thread:
http://www.polog40.co.uk/forum/index.php?topic=7975.0
Engine
1341cc bottom end, 9:1 compression ratio with forged pistons, NOS cylinder head fitted with G40 exhaust valves (sodium filled), no camshaft unless you would like the current camshaft fitted which is a turbo profile camshaft - £800 prov sold
Newman turbo camshaft £100
Camshaft vernier - £50 prov sold
GT Inlet manifold - £40
310cc injectors and fuel rail £40 prov sold
51mm Throttle Body, top part of the throttle body is blanked off so its suited for turbo set up but this part can be swapped for a standard G40 part whilst mantaining the 51mm throttle blade £150
G40 Dizzy & 8mm HT Leads £60
G40 Dizzy & 7mm HT leads £50
Uprated stiffer engine mounts £60
G40 engine loom £100
Brand new genuine exhaust manifold gaskets £10prov sold
Aquamist kit with piping, wiring, 3 litres of methanol, methanol tank and boost switch £100
Turbo set up
Rothe exhaust manifold £350
Garratt K03 turbocharger with forge actuator with blue spring (suited for 15 psi +) - £200
K03 downpipe with flexi which is 63mm so clamps to the PPP system perfectly (the wire mesh covering the flexi part has worn away but doesnt leak) £50
Spare Garratt K03 turbocharger, untested but bought as running part from ebay (no actuator) £60
Braided oil and coolant feed and return hoses and fittings for K03 plus modified sump with oil drain £50
Front mounted intercooler and all boost pipes to suit £150
Forge aluminium dump valve £50
K&N induction cone £20
PPP custom ECU chip custom mapped on the dyno for this set up (19psi of boost) £30
ECU with 300kPa map sensor £150
Full turbo set up as above - £800
Radtec Alu radiator £200 prov sold
13 row oil cooler with braided hoses and thermostatic sandwich plate £60 prov sold
Windage plate brand new unused £40
Gearbox
ATV with Gripper LSD (diff was serviced by gripper 300miles ago and had new plates fitted), will come with fresh Morris LSD box oil which is £80 for 5 litres £550 prov sold
ATV with standard diff, removed from a 80k mile G40 £275 prov sold
Helix paddle clutch with spare brand new friction plate £200
Uprated driveshaft inc CV joints £250 prov sold
Standard drivers side driveshaft with CV joints £20
Standard passenger driveshaft with CV joints x 2 £20 each
Chassis
PPP Stage 3 subframe with adjustable TCAs although these are not approved for road usage the subframe does have some wear on the lower braces where it has caught the tarmac. £250
G40 rose jointed steering arms £60
FK coilovers with adjustable dampening comes with 1 set of standard springs, 1 set of custom springs for fast road use and 1 set for track use, all threads are clean and platforms not seized £450 prov sold
Brakes
G40 set up with new front calipers bought from ECP about 200miles ago, carriers , bolts, standard 239mm discs and standard pagid pads. £125 prov sold
239mm drilled discs (recently skimmed flat and not been used since skim) 2 pairs available £40 a pair
Wheels
2 sets of 13RAs
Set 1 fitted with Michelin slicks with plenty of life left, these fit nicely under the arches even with mine being lowered and are very sticky £150
Set 2 fitted with Yoko A048rs (175/50/13) with 6mm of tread on the front (one tyre has a spilt on the tread block see pictures and 1mm on the rears ideal for track days £100
Wheel stud conversion kit £20 prov sold
Body (Genuine G40) prov sold
People who have seen the shell can tell you its not going to win any awards, its pretty battered to say the least its got a safety devices roll cage welded in and has been cut slightly lower so it fits in the car (the car has a sunroof and the cage is made for non sunroof) therefore its not for tall people..would suit midgets like myself I am 58 and I fit it in comfortably.
The shell also has bucket seat mounts welded into the floor, the front chassis legs has had additional reinforcements carried out by the previous owner.
It also has plastic windows fitted which I can sell separately if someone is interested in them.
Price wise I am not sure if its worth much so lets say £100 and if someone can give it a good home I am sure we can come to some agreement over the price.
Exhaust
PPP full system, it was the first one ever made as the car was used as the template, it did have a mid silencer however I removed it and now has a straight through pipe instead £100
Interior
Flocked dash seen better days as some areas have worn and I have cut various bits out to make the cage fit £20
Stack gauges Oil Pressure with sender £25, Boost Pressure £25, Wideband with lambda probe and wiring £150
All 3 gauges and mounting plate - £180 prov sold
Mk2 coupe s steering wheel trimmed in alcantara with grey stitching £75
Corbeau bucket seats £250 (pair)
Corbeau bucket alloy seat mounts £125 (2 pairs one per seat)
Sparco 5 point red harnesses £75 (pair)
Other parts
Headlights and indicators £30 prov sold
Throttle cable £20 prov sold
Pioneer CD/MP3 head unit £40
Brian James single axle trailer, plated at 1300kg meaning that you can transport cars up to 1000kg. You wont need a towing licence as long as the max payload of your tow car is equal or less than 2200kg. I have had it for about 3 yrs now and it tows really nice and easy to manoeuvre being single axle. These are around £1600 new I am asking for £1000
5F06F061-3491-4654-9765-08282E9521DE_zps
1841FAAD-157C-4FD0-8FDA-29934513EA87_zps
0664F182-CC64-4C57-A4F5-B391A24BB4FE_zps
7A1F4F09-0CA0-4BD9-AB5A-5F92BBA6FD9D_zps
  • Replies 9
  • Views 1.6k
Can I have the wheels?
Still have the seat mounts pal? Will they fit a mk2f ?
Still have the seat mounts but you have to weld in bucket seat mounting bars into the car.
Update, these are still for sale - everything else has been sold.
Engine
Newman turbo camshaft and tappets£100
8mm HT Leads £30
7mm HT leads £30
Chassis
239mm drilled discs (recently skimmed flat and not been used since skim) £40
Wheels
2 sets of 13RAs
Set 1 fitted with Michelin slicks with plenty of life left, these fit nicely under the arches even with mine being lowered and are very sticky £100
PPP full exhaust system, first one ever made as the car was used as the template, it did have a mid silencer however I removed it and now has a straight through pipe instead £150
Any photos of the PPP exhaust? :)
I'm also interested in the exhaust, if your willing to post?
Sorry exhaust has been sold.
Hi, you haven't got a pair of front wings knocking about have you??
Only parts that are still for sale are:
Turbo rothe manifold
GT engine mount, crank pulley and alternator
239mm vented drilled discs
HT leads
Turbo camshaft and tappets
Everything else including body shell has been sold.
