6N2 front passenger side window not moving
Hi All,
The front passenger side electric window on my 6N2 has just stopped working. Luckily it is fully closed :)
When the switch is pressed, i can hear a clicking sound but the window doesn't move. The same happens when i use the drivers side switch for the passenger window.
Has anybody got any ideas?
I guess it may mean removing the door card, so is there a best way to do that as well?
  • Views 928
Most probably needs a new motor, probably the most common fault on a 6n2, about 40 quid on ebay, easy to swap over, just needs a bit of common sence
Nice one.
I'll take a look.
