Mk2f polo coupe genesis
For sale 1.3 SPI Polo Coupe Genesis Edition.
I have owned this for just over a year now, I originally bought this as a car to run around while my other car was off the road, but I instantly fell in love with this and couldn't bear to sell it. Now however circumstances have changed and I cannot justify owning two cars.
As it is a genesis model it comes standard with the 3 spoke steering wheel and the clocks with a rev counter. It also comes with the tartan seats that only featured in the genesis. The car has a factory fitted (not dealer fitted) sliding sunroof, which is body colour to the rest of the car which doesn't leak and has no evidence of ever leaking.
Since my ownership it has been looked after by a VW technician and has been regularly serviced. I got the car with no real service history apart from knowing it had a new fuel tank and had been fully undersealed just before I got it. So I gave it a major service including, oil and filter, air filter, fuel filter, spark plugs and HT leads.
It has also had the following in my ownership;
Lowered 80/60 on TA Technix springs and shockers
Cambelt and waterpump
Thermostat, housing, and all seals/bolts
Alternator belt
Front discs and pads
2x rear wheel cylinders
Rear brake pipes
Brake master cylinder
2x front bottom arms/TCA's
Passenger and driver's outer CV joints
Ignition coil
Distributor, cap and rotor arm
Clutch
Clutch cable
Reconditioned gearbox with new oil
Selector shaft seal
Passenger rear wheel bearing
Both front wheel bearings
Exhaust centre pipe (I had the centre box cut and a straight pipe welded in)
Re-undersealed
GT arch and sill trims professionally fitted
Rear lights tinted all red
2x front tyres
The front tyre treads are currently between 5/6mm and the rears are on 3mm (I can put two new tyres on the back if asking price is met)
I have had the coolant flushed and replenished with VW's G13 coolant as that is meant to be better for corrosion properties on the engine, I also flushed out the gearbox oil after driving 500 miles with the new gearbox to ensure it was clean. It has been serviced 7 times since I bought it as I like the engine oil to remain golden. And the brake fluid has been changed.
As a car this little thing is fantastic! it is great fun to drive, and very comfortable for journeys. My place of work is a 40 mile round trip and I cannot complain about comfort. These are getting rare now unfortunately, but I honestly believe this is one of the nicest examples out there, it needs to be seen in person as the pictures do it no justice. There are a few chips and small dents here and there but the car is 22 years old! There are a few areas where the paint has been scratched and previous owners have touched it in, but without looking for it you can't tell. The back bumper has a scuff on the passenger side corner which never really bothered me. Both doors are beginning to rust unfortunately at the bottom, I believe it is a common area for these, but I do have two immaculate doors (would need painting as they are red) which could be included in the sale if asking price is met. Current mileage is 91930, but this will rise as I use this car daily.
Bad points apart from the few body work issues are:
The starter motor grinds on start up, but this is something else that hasn't bothered me, nor caused any issue
The anti roll bar can rub slightly on the exhaust manifold when setting off from traffic
The clocks have a small crack in the top left corner
The driver's side steering arm can knock on the brake servo if you hit a pothole
The headliner has a small tear smaller than a 5 pence piece
Please note: the boot does have a carpet, but it is not in the picture as I was trying to show the spare wheel/tools
That is all I can think of, but as I have said this car needs to be viewed in person to believe how well it has been kept by myself and the previous owners.
I also have lots of spare parts for this including a stainless 4 branch manifold, lots of interior trims and many more which could all be including in the sale if asking price is met.
Price: £1000ono
Thanks for looking
Any questions I can be reached on 07456842008
137C5EB9-9087-442D-90F3-912811197048_zps
101958D9-B85F-4E8F-BB80-3B1E7C416411_zps
F1AA9197-9734-4291-8552-C8B4C9D299B1_zps
CCB3987A-E306-4943-9C70-B7F4B7147354_zps
9CA390F5-A59F-4F95-878A-BDD7DF7799C7_zps
C926BB6B-C29D-4210-8EE6-93E3432E10AA_zps
71125C6C-2946-472F-B248-89D81D6DDEDD_zps
4CB926E9-1A60-4009-A276-F8C01DA6F42A_zps
0D6D0D58-5E14-489E-AFF0-F5F86E91959A_zps
2548C9C4-2E38-4FFD-9EE0-E39251A58EAF_zps
9D2A3595-6FE9-4720-B1D8-A290E850DBAD_zps
  • Views 638
SOLD
This item/s has now sold.
