6n locks help
The lock on my driver side door broke and can't be fixed, was wondering if there's a way to replace it but still be able to use the same key as I don't want a seperate key for one lock. If not if anyone can find some where that sells the locks as a set or is selling them,ignition,doors,boot,fuel cap, would be much appreciated Thanks
  • Views 777
If the lock barrel in the door broken, you can get a replacement from your local dealers and have it cut to your existing key, I bought the lock assembly from my dealership and for a tenner they cut the blades to fit my keys
Il look in to that, Thanks man
  • 11 months later...
Any tips to get in to a 2001 polo . Only worked on passenger side to begin with but now when I try to use my key it just turns and dosnt open. Boot dosnt work either . Seems like a central locking problem . Thanks
