Polo GTI 2007 9N3 - Maintenance / Faults
Had a look about but I can't really find any common faults for them really.
I've seen people say check timing belts etc, but what about the timing chain/tensioner, do they ever fail or need changing?
Any other common faults or something worth doing?
  • Views 1.6k
  • kwijibo_coupe
    kwijibo_coupe
    Posted in the correct section I think. I've never heard of any common problems with the 9n3 GTI. They have a similar 1.8 turbo engine used in a lot VAG cars from the late 1990s so with regular care t
Nothing in two days?
Is this posted in the wrong section?
They have a similar 1.8 turbo engine used in a lot VAG cars from the late 1990s so with regular care the engine itself should be bullet proof.
I know a lot of 9n and 9n3 Polos suffer with with the rear console bushes failing on the front wishbones. But replacing these with Cupra items solves this.
I'd say just general care and maintenance and sticking to the service schedule should see you right with one.
Ok, thanks for your reply.
Yeah console bushes, coilpacks (not had one go yet but it is common amongst the VAG range) definitely worth getting the cambelt done as you don't really want to bend a load of valves.
Found mine to be great so far, can't really think of any common problems!
Yours looks beautiful, everything I want.
Must be white
Must be three door.
Any optional extras are a bonus.
If you don't mind posting, how much did you pay for yours? / what do you think it's worth?
