How much brake fluid
Hi how much brake fluid should I buy to do a complete change on my mk2 bread.
  • Views 2.7k
1 ltr should do it
Cheers Steve what grade would you use. There only standard brakes.
just dot 4 fluid
1 litre should be loads, if the parts place is alright with you, I normally grab 4 500mls and take what I dont use back. Running out part way through bleeding the system is a massive pain in the arse.
