Polo 6n Rear Suspension
Hey ALl,
Well the Polo is finally through it's MOT
However, the lady hit a harsh pot hole yesterday which pushed the passenger side strut through the strut top.
Fixed it before she went to work yesterday, however she has had it happen again today on the way to her sisters.
Would this be a replacement shock jobby?
Tom
  • Views 2.8k
If the bodywork where the strut mounts isn't damaged/distorted then you probably just need the top mount rubbers
post-36925-0-93396700-1431344733_thumb.p
3 6N0512103A spring disc lower /
4 321512109 base lower /
5 6N0512113 spring disc upper /
6 191512117 spacer sleeve
7 191512119 ring 4,1X20X11,1 /
8 6N0512131A stop buffer / F >> 6N-W-098 090
(8) 6K0512131A stop buffer / F 6N-W-098 091>>
(9) 6N0512135 protective cap
10 6N0512149 base upper /
11 191512333 bearing ring lower /
12 191512335 bearing ring upper /
13 191512337 concave washer
14 N 10328602 hexagonal nut M10X1 /
15 191512339 pressure washer
16 191512340 support washer
17 191513269 protective cap
So on that picture number 11 and 12?
Yep more likely to be # 12 & make sure # 15 hasn't distorted and the #14 nut above #15 is tight
