Full GT engine conversion and rebuild kit for sale!
Hey guys, I'm just seeing what interest i get in my full gt conversion i have, I'm not desperate to sell but i will do for the right money...
I have the full gt engine with mounts, dewedged throttle body, inlet manifold, gearbox, engine loom, ecu, air box and afm ( only parts missing are the gt camshaft and exhaust manifold )
The rebuild kit contains ( brand new and cost about £140 all together ) timing belt kit, water pump, head gasket set, head bolts, inlet valves, exhaust valves, sump gasket, oil seals, 1x crank case NOS gasket ( only parts needed are bottom end bearings and piston rings )
I want to sell as a whole really because i dont wanna sell the engine and be stuck with all the gaskets and rebuild stuff... engine had done 82000 before i took it out, head has been removed and I've had a few bits shot blasted ready for paint ( engine mounts, alternator bracket, bottom pulley and cranks casings )...
will need picking up, located in bridlington east yorkshire, whole lot for £250
  • Views 564
hello mate ill take this please... just need to sort out picking up off you....
Hey mate, where abouts are you? I can box it all up for you so there will be a few boxes lol...
ill take the rebuild kit if its not wanted by the other guy
If it falls through I'll take it :)
I want to sell it all as a whole really, pmd you sircar... if he doesnt want it tho i might split so will let you know mate cheers
i'll be interested in taking the whole thing? next wed i'm driving ffrom brighton to tamworth if that helps?
