common issues on 9n 02 onwards
hello people
started looking at the 02 shape polos 1.2
I've had countless coupes.... breadvans, 6n, 6n2. also 6kvs. just wondering what the 9n is like compared.
do they still suffer pedalbox failures? gearbox? any input would be welcomed as I'm now considering purchasing one
cheers
  • Views 426
The biggest weakness is that 1.2 engine :( it tends to eat valves, if there is any sign of a missfire or if you can scan the ECU and see if there are any codes related to missfires, if there is walk away !!
Gearboxes are 02x series, so not made of chocolate like the 085's in the 6N/6N2/6KV's
Pedal boxes are OK as the clutch is Hydraulic so totally different design :)
thanks nige
i did read about the valves somewhere.... the gearboxes i wasnt sure of.
cool
