Rear badge removal
Hey I have just joined Club polo and was looking for some advice.
I was wondering if there is a way I can remove my rear badge without damaging the paint work. I was hoping to spray it black then put it back on.
  • Replies 8
  • Views 4.8k
  • Cheers guys I managed to heat up and then use floss to take it off
  • have you done any of the other badges? the "Polo" bit ? i need to remove mine and put new ones on but I'm not sure on the best way to re-apply them
  • louulouuxox
    louulouuxox
    To get the 'polo' and lettering of my car, I used a bucket of hot soapy water, held the sponge on each letter at a time, then carefully using dental floss worked them off one at a time! Then used
On my 9n1 I found that heating the badge with a hair dryer, then cutting through the double sided tape with tooth floss did the trick. Once you've removed the badge, it's just a case of using your fingernails while continuing to heat with the hairdryer. I was tempted to use a screwdriver with a cloth behind, but that probably wouldn't be the best idea!
Welcome to the forum :)
Most of the badges can be removed with the application of gentle heat and either a plastic credit card to gently pry the badge off or again with the heat, cut the badge off with dental floss
Bit of warm water and a credit card eased the badges off my 6n.
Managed to spray it and stick it back on
then carefully using dental floss worked them off one at a time! Then used an old credit card or my nail to GENTLY scratch off any foam pad left on
Then if you want to reapply the OLD badge, I scraped off any foam that was on the old lettering,
Then used 3M number plate tape (think that's what it is) and cut around the letters with a fine pair of scissors
Make sure the area you want to stick it on it clean and dry and, voila, done
Hope that helped :)
If you don't have a heat gun, or in my case an extension lead long enough to reach the driveway, just pour hot water over the letters/logo and pull it/them up with a credit card/plastic trim removal tool.
Edited by DUOTEXO
