Headliner Fabric?
Thinking about covering the existing headliner with different fabric and hoping to spray/glue it on. Wandered if there's a specific type of fabric that would be good for this?
I will be removing it too so that the fabric sits under the seals etc. don't want it to look like a bodge job!
  • Views 1k
If your going to stitch in around the edges ( sunvisor/ front area ), you can use anythink you want, if not you'll want something über flexible and strechy to avoid getting creases or folds.
I'd be mega impressed if you done it without removing it!!
Edited by SuperMario
Thanks! Haha I think I'll play it safe and just remove it!
Takes around 20 minutes to remove the headliner and need nothing more than a crosshead screwdriver.
Didn't realise it was that simple! Cool I'll give that a go when I've got the fabric. Thinking of going for something a bit different. Will post a photo if all goes well
Open all 4 doors and the boot.
Pull the door rubbers down (these may be stiff but give em a good yank)
In the boot at the top at the back of the headliner is a plastic trim, yank away.
Pull the top of the B pillars out, then the top of the the A pillars.
Unscrew all 4 grab handles
Detach centre light unit, disconnect wiring and put aside.
(If you have sun roof, look up the rotary switch to find two hiding philips screws)
Disconnect sunvisors and centre sun visor and their mating clips.
Remove the headliner via the boot
(if you have sunroof you need to pull towards boot, then remove rear of sunroof's clip, then push forward and remove front of sun roof clip)
Thanks that's super helpful! I'm new to all of this and my polo is my first project. Those instructions are great :D
Good luck and you're welcome
