Adventures in Polo restoration....
Yeah, satin black is easier to get a decent finish on overall
  • Replies 142
  • Views 21.2k
  • AveryCates
    AveryCates
    Hindsight is a wonderful thing....but you can only piss with the cock you got!
  • Made up my drive shafts this morning Hubs are in the freezer before I fit them to the swivels....my wife knows, isn't impressed but understands what I am trying to achieve!
  • I normally try to do my car part cookery when she isn't in....what she doesn't know can't hurt! Finish making up the front subframe, may try to fit it tomorrow. Though still need to make up
And fluff seems to be sexually attached to gloss!
Did a little bit over the weekend as the weather was nice...well the floor was dry!
fitted the new rear beam, went a lot easier than expected. I did use bolt cutters to chop the hand brake cables and brake pipes.
I bleed the brakes, but because the caliper pistons were wound all the way in I still need to adjust them a little so they work properly. I should do that this week, if the weather holds out and have a look at the wonky steering!!
Well, the weather was rubbish all week so no new progress on the car....but these turned up today
Not the size you were expecting [emoji16]
Sent from my HTC One A9s using Tapatalk
Just collected my latest batch of plating, shiny as ever!
And I have dropped the wheels off to be refurbished, hopefully be ready in about 2 weeks!
The plating looks excellent (as does the rest!)
Do you have a link?
Do you have a link?
 Plating - http://www.allenchrome.co.uk/
Wheels - www.raw-wheels.co.uk  (Picking up wheels on Monday :D)
Been busy on the house this last week, decorating and having new doors fitted....so still very little progress on the Polo unfortunately. I did manage to get the gearbox to a local company for a rebuild/strip and check, should be back with me towards the end of next week.
Put my PAS pump back together
And my AC compressor
And these bits arrived .....
Should have a few of the missing pieces later next week....
Just picked up my wheels...
Need to see what the gold looks like on the car!
Who do you use for your plating?
Edited by Duffy
1 hour ago, Duffy said:
Need to see what the gold likes like on the car!
Top of previous post....Allen Chrome, Pocklington, near York.
From the bottom of this post..
thanks!
:D
The bolts and wheels look amazing!
Few more bits arrived....
Fuel pressure regulator (specially for injection to carb pressure)
Mk2 Dizzy
Also picked up the gearbox after its rebuild, the guy said it wasn't too bad just some wear on the main bearings. I was thinking of having it vapour blasting to look like new....but thought that might just be a step too far. So it was just degreased and cleaned
And fitted the centre caps to the wheels, if the weather stays nice I will fit the wheels tomorrow
  • 7 months later...
Well, it has been a while since I posted anything on here....kinda lost the will after the changes to Photobucket, but new picture host hopefully everything will be good now. Shame most of my thread is blank now....I shall try harder to upload things!
The majority of the summer I have spent at working at sea and selling my house. With the move looming I decided to pull my finger out a little bit and get the car road worthy at least for the move to a new house. We are moving from Hull to a village near Scunthorpe.
So the wonky steering needed sorting (which I never really looked at) and an MOT was over due. In true DIY mechanic fashion....i took it to my local garage and sheepishly told them I'd done something wrong and asked them to fix it.
Well, the steering was simply a geometry problem. With everything coming on and off a few times everything was out of kilter, so everything was re-aligned.
It also flew though the MOT, no advisories.
37968083001_a18745dba2_b.jpgScreenshot-2017-10-27 VOLKSWAGEN POLO - Check MOT history by Thomas Banks, on Flickr
All I need to do now is pick it up on Monday morning.
All my tools, car part etc are packaged up at the moment so there will be no progress with the new engine over winter. Unless I cave in and find a garage to do the work for me!!
Fetched the car this morning, the garage gave it a wash as well...
37982040246_d6663162c5_k.jpgIMAG2394 by Thomas Banks, on Flickr
The new alloys, that I don't think I ever showed...
24183266538_9744ec0cbc_z.jpgIMAG2395 by Thomas Banks, on Flickr
  • 8 months later...
What happened to the polo? We need more updates! 😀😀
You're making me want to strip mine down!!
  • 2 years later...
Wow over 3 years since I last posted anything here....I guess that's what happens when you buy a new house that is a wreck, then spend all your free time & money trying to make it habitable.
Click HERE for the original advert, we don't think the previous owners did any decoration and they moved in around 1980. So after a replumb, rewire, walls stripped, replastered and repainted I am now just waiting on carpet for the last room.
I can throw up a few after images if anyone is interested....but this isn't called Club House Renovation after all.
Edited by AveryCates
The Polo is still going strong, passed its last 2 MOTs with flying colours (next is early Feb) but it is largely the same as my last update here. I did swap back to the 15" BBS wheels as the 16s raised it up a little high. The lack of a proper garage is now my only issue, I have  a double car port but this time of year it is a little chilly so there is no progress.
My plan for the next year isn't terribly exciting, gearbox & clutch swap so that it is a little easier to drive. Currently the clutch doesn't fully engage, making gear changes hard and sometimes stalls the engine. There is no adjustment left on the cable, and the clutch has done over 100k so it's time for a change.
I don't think I am going to be doing the AFH on bike carbs swap any more, I've spent way too much on the house and need to top my savings back up. So all the parts I hoarded need to be sold on along with the 16" BBS wheels..
