mot
I am going to be putting my polo through an mot in next couple of weeks is there anything I need to be looking out for on the car that they are prone to fail on any info greatly appreciated
  • Views 782
a mk2 could have lots of faults if its been neglected in the past, you can check stuff like tyre tread , lights , wipers etc , have a look underneath for any serious rust , make sure its running well and serviced recently for the mot emissions
i always like to take a decent long run on the way to the station to make sure the engine is up to temp and the cobwebs blown away
Lights, tyres and wipers
Rust, particularly at the back of the driver's sill.
Handbrake not pulling up evenly
Play in the back wheel bearings
Oil leaks
Offside anti-roll bar bush perishing as a result of oil leak.
Play in the front top mounts.
Missing rattle clips on the front seats.
This http://www.motester.co.uk/mot-guideis a good guide.
Oil leaks
Good list there.
I'd add checking the condition of the brake pipes and flexi hoses to it though.
I was about to say, my 6n recently failed on corrosion in the brake pipes towards the rear, and deterioration of both front flexi hoses. As well as both offside wheel bearings (front and rear) and an advisory for the nearside rear bearing.
Not sure how much these problems correlate between mk2 and mk4 but mine looked like they'd not been done before when we replaced them.
ok thanks for the advice I have looked at lots of things and it seemes in very good condition it has had new brakes and new suspension before I got it couple of months ago so I know all that is fine. I know top mount needs doing but I know that's easy enough so hopefully will be all fine
i always had a problem with brake blance with the drums. cv boots too
