Help Brake pedal drops and having to push it back up
need a bit of advice I have a 6n2 and whenever I use the brake the pedal it works fine and stuff but the pedal does not come back to the top therefore keeping the brake lights on all the time unless I push it back up with my foot. I have heard it could be the pedal box but was wanting to see if there is any other suggestions. The accelator pedal also can be pushed up but when I use that it clicks back down.
  • Views 560
First Welcome to the forum.
The pedal box problem normally only affects the clutch pedal, there is a return spring on the pedal that might of snapped or the pushrod from the servo might of come out of the locating block in the pedal, you'll need to stand on your head with a good torch and have a look at the pedals :)
Ok mate thanks will get a look tomorrow starting to get annoying when driving having to constantly push it back up.
