POLO 6N 1.0 1998
Polo 1.0 complete White
Failed MOT - Needs 3 small areas welded by rear arches, a rear wheel bearing and lambda sensor
Breaking as my daughter no longer needs it All parts available
Here are some guide prices
Engine complete with injectors manifold etc (runs really well) £150 but you remove it with my help as I don't have lifting gear
Full interior grey (no tears but could do with clean) £100
Set5 wheels and tyres with good tread £50
All panels available and solid but some could do with blow over Rear panel below bumper probably the straightest I have seen
All ancilllariies - Alternator Radiator Starter ECU etc
Front indicators I have both clear and original sets
Almost new catalytic converter
Complete exhaust
We're based between Portsmouth and Chichester if you want to come have a look
Call if you want to arrange 07917330669
Happy to post small stuff or be here if you want a courier to collect
Can supply more pics if needed
post-920798-0-56735700-1433590831_thumb.
  • Views 794
How much for the drivers side door hinges? Cheers
Will only sell these once I get some interest in major parts (engine etc) cos I can sell complete to breakers but would lost about £100 if door hanging off
As soon as I get interest in the big stuff will get back to you
I have no idea what these are worth so what are they worth to you
£10
I like the wheels. The 5th one is the small spare one? Can you send by courier?
Pm if you want :)
hi
I have sold the wheels but not the trim rings (white bits that make them look good)
If you are interested in these I can send them as they are plastic and easy to post
I am look at £10 for these (set of 4) as they are quite rare
You can spray these any colour you like to match you polo
They will also fit MK2 and Mk4 13" wheels
