Running gear from my G40
Hi there, as the title I have a list of parts I am selling. Quite willing to do deals if buying a lot of stuff. Postage is available on the smaller stuff, otherwise collection is from Sheffield although I am travelling about a bit over the next few weeks/months so get in touch if there is something you want and are miles away.
I will take pictures of things if needed.
Engine, it had the head rebuilt about 20k ago after a head gasket failure. Does not smoke and feels very strong, has always made good power. New cambelt and waterpump 2k ago in May of 2013. £300 SOLD
Gearbox with Quaife LSD, covered around 1200 miles since fitting. Fitted at Stephen Brears gearboxes in Leeds, gearbox was stripped and new second gear synchro fitted. £850 SOLD
Standard ATV G40 gearbox. £300
Lightened flywheel as Pete was doing. £70 SOLD
Helix paddle clutch. I was using this with a standard pressure plate (which I can chuck in) and it was fine. Covered 2k miles. £100 SOLD
Ported GT inlet £40 SOLD
FK Konigsport coilovers. £350 SOLD
256mm Audi brakes with discs/pads. £200
Vernier pulley. £100 SOLD
Braided brake hoses. £20
In line fuel pump. £35
In tank fuel pump. £15 SOLD
Alu Direnza radiator and slimline fan. Also comes with adaptor for the temp sender as they are a funny size for some reason. £150 SOLD
PPP exhaust, cat back system. Slight graze from a rubber failing incident. £300 SOLD
Engine loom, only issue with this is the plug has been cut off for a slimline fan. £80
Steering damper. £35
Starter motor. £20
Dewedged throttle body. £50
Standard exhaust manifold. £20
G40 engine mount/charger bracket. £20
Varta battery. £15
14” OZ F1 wheels with Yoko A539’s. £350
14” Compo MO with Khumo V700 track rubber powercoated in white. £400
Late spec rear lights with euro fog light. £40
Set of headlights with clear side repeaters. £40
VW Front rubber floor mats. £20
Dizzy with cap and HT leads £60
PSD catch tank with hoses to go to breather. One of the take offs has broken off. £10.
Edited by SamG40
  • Replies 11
  • Views 734
Inbox is full buddy. Tried PM'ing about the steering damper
Edited by ska_wars
What make vernier pulley is it dude?
Are you going polo social?
i'll take the braided brake hoses please
need a posted price
ta
Hi, the exhaust, is it from the cat to the backbox? No manifold? Also are the fuel pumps genuine g40 ones? Thanks
Room in the inbox now.
Not sure on the make I'll look tonight and no not going to the polo social.
need a posted price
ta
I'll pm you.
Exhaust is from the cat back, it was used with a turbo which is also for sale on CG40. Yes fuel pumps are G40 spec.
Post updated and some photos added.
7A953625-BAEC-43CD-8C9E-4BEAA35D5C32_zps
11C68025-28B9-441E-BCA6-DCE19255B2C6_zps
922FFABA-420F-45CC-A4DD-469E23ABF8A0_zps
2FA2824F-96D9-4561-ADE3-A5C06FBF2BE4_zps
301F5B98-5D09-44EE-8490-4C8EE01AB6B1_zps
75C0FA22-D3D6-43CC-B21E-6D0FB19E2A50_zps
FB969AF3-E35D-4D0A-A9EC-F930555810F8_zps
Hi mate,
Is the standard g40 box still for sale
The PSD catch tank. Is the take off repairable? Any photos
Gearbox is still here.
Catch tank picture is above. Probably not really repairable. I just shoved the hose through the hole as above on the outlet. It stayed where it was supposed to.
Would it not be able to weld a new take off on?
Could you pack the box for a courier ?
