6N1 ABS light location
Hi, I have a 1997 6N1 1.4 74kW, where is the ABS light located? Should it be in the instrumental cluster? Anyway I opened it up and thats what is inside:
post-920873-0-33708300-1433947875_thumb.
Edited by fronogy
  • Views 2.2k
post-36925-0-32549100-1433952359_thumb.p
1 - Left turn signal
2 - Main beam
3 - Right turn signal
4 - Fuel gauge
5 - Fog lights
6 - Anti-lock brake system (ABS)
7 - Brake wear warning
8 - Brake test / brake system fault warning
9 - Glow period check
10 - Alternator
11 - Oil pressure
12 - Airbag
13 - Turn signal repeater / side light check
14 - Rear fog light
15 - Coolant
I've only ever seen the separate abs light unit which goes under the airbag light near the hazard switch.
From the ones I've taken apart I don't remember seeing a symbol for abs as most of them are blacked out.
If you hold that black plastic strip up to a light you can see the symbols through it, then just match that up to the bulb.
Edit- I've just looked at the picture again and position 6 is the seatbelt warning light
Edited by dixy
