'87 Breadvan Ranger
The cars a 1.3 ranger with a weber dmtl
TA coilovers
ats classics
The car came from the factory in tornado red and the previous owner to me had it painted very poorly in purple i got it almost 2 years ago now for just over £700 which was probably to much for a rusty bready, anyhow I've always had the thought of respraying it my self and its slowing happening but now i have the task of rear arches :-( to say they need replacing would be an understatement
this is the night i got it
18126415854_6f23840cb8_z.jpgDSC_0562 by lukeherbert1, on Flickr
18561265448_bcb53d6792_z.jpgDSC_0764 by lukeherbert1, on Flickr
then i painted the wheels black :|
18722757636_06d2f8130d_z.jpgDSC_0783 by lukeherbert1, on Flickr
then i cut the springs and fitted some classics and painted the front for a halloween meet
14018730066_d138dde060_z.jpgUntitled by lukeherbert1, on Flickr
i then started sanding off the purple to reveal the red and at this point the car was on -80mm lowering springs with -20mm lower spring seats
18561475080_3340f27244_z.jpgUntitled by lukeherbert1, on Flickr
and then shortly followed with coilovers all round
then started the prep for paint with new wings a bonnet
18749342045_d80b7d3b06_z.jpgUntitled by lukeherbert1, on Flickr
18561608290_d879b3aec9_z.jpgUntitled by lukeherbert1, on Flickr
18561607010_532f213ce4_z.jpgUntitled by lukeherbert1, on Flickr
Edited by lukeherbert
  • Replies 52
  • Views 6.6k
  • lukeherbert
    lukeherbert
    fuel filler area is almost done now Untitled by lukeherbert1, on Flickr
  • lukeherbert
    lukeherbert
    took 3 days of work and got the polo in the garage and cracked on with the intention of painting it the following week when i go of for training as i can paint it for free but hat never happened and i
  • lukeherbert
    lukeherbert
    and finally the rest of the car is painted! but I'm going to redo the bonnet and n/s wing Untitled by lukeherbert1, on Flickr Untitled by lukeherbert1, on Flickr Untitled by lukeherbert1,
this is when it gets exciting i took it to college and painted some bits
18128663903_0042386bd0_z.jpgUntitled by lukeherbert1, on Flickr
18751788661_a4c7c620a3_z.jpgUntitled by lukeherbert1, on Flickr
18561546938_7c8f47f7b1_z.jpgUntitled by lukeherbert1, on Flickr
18749210215_00c3d59ca4_z.jpgUntitled by lukeherbert1, on Flickr
18749199255_3b1ee9f281_z.jpgUntitled by lukeherbert1, on Flickr
18722895866_3454d62a19_z.jpgUntitled by lukeherbert1, on Flickr
18563018629_a2d57eafdf_z.jpgUntitled by lukeherbert1, on Flickr
and heres my next challenge
18561380768_55a6c995e1_z.jpgUntitled by lukeherbert1, on Flickr
turns out a mk2 golf repair panel is perfect
18561463720_f03f9bd32d_z.jpgUntitled by lukeherbert1, on Flickr
sorry for the picture whoring :D
Good progress, nice and low.
How are you finding the TA coilovers?
Lovely thread
The fronts are quite nice but the rears are way to soft
coilovers not too rough over bumps?
the standard ta technix spring and shock kits are horrific so I was put off the coilovers. I'm looking for something not much harder than standard really for comfort
No the ta coilovers are completely different to the ta shock kit, I'd recommend the the coilovers
i got my maxrpm topmounts and caster correction arb mounts
18158402234_3cc5e15913_z.jpgUntitled by lukeherbert1, on Flickr
and today i started cutting :-(
18776054302_9087888f77_z.jpgUntitled by lukeherbert1, on Flickr
18781007955_acc50da909_z.jpgUntitled by lukeherbert1, on Flickr
I'm enjoying this thread already, keep up the good work!
Bit more cutting today, I spent the day mostly making panels
18809195872_79a7ee8426_z.jpgUntitled by lukeherbert1, on Flickr
got a fair bit of welding done in the last few days but still loads to do
19091805058_51c4e3b499_z.jpgUntitled by lukeherbert1, on Flickr
18658850233_270e7896ab_z.jpg by lukeherbert1, on Flickr
its funny how the bottom of the back of the arch has absolutely no rust but just above its paper thin
19540210051_b5159d2333_z.jpg by lukeherbert1, on Flickr
19509833336_2c4e819f9c_z.jpg by lukeherbert1, on Flickr
18915073183_4bf91f6e4f_z.jpg by lukeherbert1, on Flickr
19644790925_ceeae71b39_z.jpgUntitled by lukeherbert1, on Flickr
Been following your progress on Instagram. Looking really good :)
Great work!
Keep going, bud.
forgot to update this so heres whats happened in the last 2 weeks
arch on
19842439616_5fe8b31e7e_k.jpgUntitled by lukeherbert1, on Flickr
then the sill
19682028029_92a0b327fb_b.jpgUntitled by lukeherbert1, on Flickr
19682041769_f551ea4b1f_k.jpgUntitled by lukeherbert1, on Flickr
19680637230_c0cc3c09f7_b.jpgUntitled by lukeherbert1, on Flickr
then filler, primer, seam sealer followed by stonechip
19766759280_e8ebe86ca5_k.jpgUntitled by lukeherbert1, on Flickr
and then brushed on polyurethane top coat
19928523386_35a0b5fbe5_k.jpgUntitled by lukeherbert1, on Flickr
19928514126_2d7606e298_b.jpgUntitled by lukeherbert1, on Flickr
19947097992_07426d55c2_b.jpgUntitled by lukeherbert1, on Flickr
Awesome work mate the rear arch looks brilliant. I'm a novice to welding who is looking to undertake the same work on my 91 breadvan rear arch/sill popular grot spot. Is it difficult to do ie could I self teach and have a go as I have all the repair panels ? Are you mega experienced as the repair looks superb and I am aiming for the same proper long term repair.
Thanks man there's been a hell of a lot of man hours in this, I could weld very well when I started this but I had some idea of what I was doing as I work in a body shop, this is the first time ever done this sort of fabrication and sill, arch replacement, it's a massive learning process. If you're busy all the time expect to spend at least 1-2months on this area, it's quite a difficult repair as you need to make the tank you're repairs. The rot in mine was really bad and I had to make the whole jacking point and inner sill
Nice metalwork, I've seen a few pictures of it on instagram too. How much hardener did you use in the paint when brushing it on? I Need to do a few bits on mine
Edited by Fungus
its been a while since I've been able to update but I've put in some serious man hours and I've really impressed myself, and to say i've done all the metal work, filler and paint is something to be proud of
20771118864_74b4e01f19_b.jpgUntitled by lukeherbert1, on Flickr
21382981942_1d07fc5d19_k.jpgUntitled by lukeherbert1, on Flickr
21206941719_329fdbd6ab_b.jpgUntitled by lukeherbert1, on Flickr
primer
21367603616_463fd34cfb_k.jpgUntitled by lukeherbert1, on Flickr
wet on wet self level primer for extra sealing and coverage
21205753820_55df4e9330_k.jpgUntitled by lukeherbert1, on Flickr
21382986852_921fbf939c_k.jpgUntitled by lukeherbert1, on Flickr
20771163524_ac9c5376b9_k.jpgUntitled by lukeherbert1, on Flickr
20771170974_40b37591ee_k.jpgUntitled by lukeherbert1, on Flickr
21383011922_20505bf43d_k.jpgUntitled by lukeherbert1, on Flickr
Paint looks amazing and a few good shots there!
car look superb, good for you.
you put the work so I hope you enjoy it, love the front wheels
Agreed, the front looks well stanced and the paint looks good from here too.
What are your plans for the rear?
A job well done 👍
