Bonnet catch
Hey polo people. Hope you're all amazing and getting chance to enjoy the sun. I looking for some guidance with my stock 1983, 1043cc bready. More specifically, the bonnet catch. Has anyone switched to a different system on their polo that is easier to use or less maintenance but still MOT/VOSA worthy, than the stock system? I'm just looking at options at this point.
I ask mostly as i'm having issues with the assembly that fits behind the grill. I've fitted a brand new release cable, following the haynes as closely as possible but it doesn't seem to work. I've been carrying around a long screwdriver to open the bonnet if need be, and that doesn't look good if i get stopped for any reason.
I did have an idea involving bonnet hooks and pins. Like the motorsport ones. Not sure how practical that would be though as i've literally no experience with them beyond seeing them in pictures.
Thanks for stopping by and for any guidance you're able to leave.
Churz!!
  • Views 511
Normally it's just the catch itself that's seized. Bit of WD does the trick short term, once it's free dry and clean, grease it up.
I've whipped the catch off and gone to town with the wd40. It's got plenty of movement, but i think i must have put it back together wrong cuz it just doesn't seem to work. When i put the cable in place and pull the release handle, it just pulls itself out of the handle. I've got another assembly on the way but i'm now toying with getting rid of that lot and fitting aero catches. When budget will allow. X
race car catches only belong on a race car imo
stick with it ...no reason you cant get a standard part to work
I get that. If the replacement part i have on the way fits out of the box, i'll probly just leave it at that. Was just looking at options to make it simpler. Bonnet catches seem to be the simplest long term method so far, bar the actual fitting.
