Just a newbie question
Hi there
I'm just wondering cause I wanna lower my 95 6n
But dunno if it's as simple as buying coilovers and fitting and adjusting them I wondering if I need owt else to lower my car.
Many thanks
Carl
  • Views 529
  • No, just buy the coilovers fit them and adjust how low you want to go, then get the tracking/camber checked/adjusted as lowering will affect the tracking/camber
  • On the later Polo's you do need shorter drop links but the 6N is a simple "fit n play"
Many thanks as you could see why I thought that tho plus someone mentioned to me shorter drop links and different tie rod ends.
But I thought I'd bring it to here where most people deal with polos and encountered problems like this.
Thank you
Carl
Edited by Tweakz
Ah okay many thanks
