might miss the polo social
So it was bound to happen after losing coolant 3 times at high speed - my Polo's now got the classic headgasket oil leak above the alternator.
I tried using some Laco oyltite stick to contain it - but it's only good up to 1 bar and the main oil gallery is at 7 bar pressure when cold and 3 to 4 bar when warm (and the oil will only aim for the cambelt just like water aims for your elbows). It's the original headgasket and it has done nearly 200,000 miles so quite impressed.
I've got a lot of planned engine work so having to take the head off is not a problem, but the timing's unfortunate as my neighbours are having building work done and the air's thick with brick and cement dust. More to the point Polo social is weekend after this one.
So with only 1 weekend and some evenings free, do I
  • soldier on daily with some sheet to protect the alternator and keep an eye on the oil level and pressure - and attend the Social
  • perform most of my intended engine work - remove head and pistons - hone the bores and fit new piston rings and replace the head with my replacement skimmed BVH moving some bits over from old head (spray bar, thermostat housing, dizzy ring,camshaft, followers) and maybe go just Sunday
  • just replace the headgasket keeping current head if not warped
I do want to finish all the engine work (and some bodywork) for the Shelsey RetroRides event.
  • Replies 12
  • Views 661
  • kwijibo_coupe
    kwijibo_coupe
    Do number 3 at the social. A new gasket should at least get you back home. At least it isn't a K series Rover engine...
  • It's not hoofing out. A tray overnight had caught about a table spoon of oil, and I've done about 100miles since and oil level looks the same as yesterday. I've covered the alternator for now (silver
  • mark_crox
    mark_crox
    That just means they are going to use your garden... watch where you step!!
Bugger. 200,000 miles is bloody good though :)
Humm it's a tough one. I would say number 1 or three and attend the social.. or do number 3 at the social :)
Ooh, number 3 at the social sounds good. Fill your boot with tools and spare parts!
I'd say attempt number 3 and hope the head's not warped. That was you can come to the Social and maybe start the whole engine work the week after?
200,000 miles on the original head gasket is a good old run though!
:lol: We can have a club fix-it.
I'll chuck the a-frame in the boot and drag it home if it doesn't go to plan.
Mines been leaking for ages.... its not a leak - its rust proofing ;)
Had a friend with a K series Rover and he replaced the head gasket. It went again 242 miles later. I believe 'fuming' is the word.
is it hoofing oil out? they can leak for 1000s of miles and cause no bother other than soaking the alternator , id hazzard a guess that theres not that many that dont leak there
a gasket and bolts isnt that dear ....you can swap the head in a afternoon if need be , i would be tackling the re ring job if theres building dust near the car
I've been known to knock another 90 degrees on the headbolts in that corner when it starts leaking. Pikey, risky, but can work.
I've covered the alternator for now (silver foil, cable tie).
There's quite a lot on the sump but it's hard to tell how much is escaping or how long that covering has built up.
Polo social visit looking more likely.
Next door's builders have taken away the portaloo - but there's still one wall to demolish..?
Definitely helps focus - now found and ordered some new mechy rocker arms, part
Part number 029LB18191300 I think.
That just means they are going to use your garden... watch where you step!! :D
