Wheel Weights
Got a really strange pulling on the 6N, it pulls to the left and after close inspection I have found that there are two different sized wheel weights one being larger on the left, could this be the issue ? I have recently lowered it on 60/40 springs if that helps, cheers
  • Views 699
The wheel weights are different sizes for the different weight required to balance the wheel/tyres it will not cause it to pull in any direction, you said you've recently lowered it ?? did you have the steering/suspension aligned after you did this?? as fitting the lowered springs you will of disturbed the geometry of the suspension and this will cause it to pull one way or the other
thatll be it ! can it be calibrated ?
Yes. You need to get your wheel alignment checked and they will adjust it for you.
smart, job for payday then :) cheers was getting annoying
If you leave it too long it will possibly ruin your tyres as well :(
Pay days on Friday ;) new wheels soon which means new tyres
