Removal of trim
Hi there, not sure if its possible or not but has anyone ever removed the trim that is on the doors and filled it.
Picture probably explains what i mean more.
If anyone has done this before, what is need to do it and any pictures on what it would look like..
Thanks Zac
post-920906-0-60772100-1435094848_thumb.
post-920906-0-85431400-1435094883_thumb.
post-920906-0-16257500-1435094890_thumb.
  • Views 773
I just used a Hair dyrer and WD40 to get all the gluey resedue off, not sure how you would fill the holes though
Ok, Did you just spray them and put them back on? Or do you not have them on at all?
Sand inside the indentation of the hole. And skim over with filler light sand till silky smooth and the prime and paint the car looks better without them.
If your planning on painting them then leave them on.
You can paint them on the car and will look the same if you take your time and clean properly.
Filling them from outside will look okay, but will eventually crack in a perfect circle over time. This is because when you smooth the filler over the hole it creates a tiny finger inside the panel, and this usually weighs a bit and will move with vibration. It may not show itself of decades, but could only take a week sometimes.
Best way would be to weld these holes closed.
Sure it looks good to have a full shiny panel of paint, and all is well, right up until you open the door and smash the crap out of the edge or even better someone does there best in a car park and smash directly into the middle of your door with there's. What would have been a tiny ding to the plastic is now a huge dent with a lovely contrasting scratch and probably cracked paint right in the middle of your panel :)
I've only just read this, but if dixy hadn't said it, I would have. :smile:
Regards
Thanks for that, will get that done in the future when it comes to getting a 're spray. Thanks
