mk2 twin spotlight grille
Just got a new twin spot grille for my polo, had one as a teenager and I remember just plugging it straight in and it working.
This one has no plugs, is there a 'plug and play' adapter I can buy for it?
  • Views 536
Welcome to the Forum.
If you are saying that there is no wiring in the car to which you can connect, then you will need to provide the wiring and a relay.
for best results, I would recommend that you use 28/ 0.30 mm cable to supply the relay contacts, and also to feed the lamps from the relay.
The feed from the switch to the relay coil can be much lighter, as it doesn't carry a heavy current.
You can get all the bits that you need for this job from www.vehicleproducts.co.uk for the catalogue or email sales@vehicleproducts.co.uk
Regards
