Leftover polo parts
All this needs to go!! Prices don't include postage. Any questions just ask.
Coolant bottle cap x3 £1 each
Rear suspension cap x3 £2 each
Rear arch spats £5 all 3
Window winders x6 £2 each
Bonnet water seals £4 pair
Inner door handles £5 pair
Headliner light £3
Big VW badge £5
Wing mirror cover £2
Washer bottle pump £5
Front suspension caps £1 each 4 SOLD
Sparco pedals £10
Light switch x2 £5 each
POLO badge £5
Leather gear knob £5
Sunroof handle pocket £2
Inner door handle trims 2 passengers left £2 each
Water hoses £2 each
Seat adjustment hooks (wrapped in the masking tape) £5 pair
Dash big blank 1 LEFT £2
Boot VW badges £5 each
Radiator rubber cups x4 £5 pair
Rear door card tray £2
Seat belt covers £1 each 1 SOLD
Door hinge x2 £5 pair
Bonnet release handle £5
Wiper nut covers £4 pair
6n thermostats (new) £5 each
Battery clamp and nut £4
Wing mirror knobs and gaskets x2 of each £1 each
Bumper holders £5 pair
Window mechanism £15
Everything else in 2nd picture £5 a piece
3 big hoses SOLD
Interior headlinder material £5 all 3
Passenger air vent £5
Fuel rubber seat/cup plus cap £5
Exhaust hose £5
Roof water drains £10 all 4
Dash air channel£2
Rear view mirror £5
Lambda £10
Door trim £3
Passenger handles £5
Dash speaker cover x4 £10 pair
Horns x3 £5 each
Windscreen body panel £10
Brackets £5 pair
ARB brackets x4 £5 pair
Bonnet catch £5
Door catches £5 each
Full set of seatbelts £15
Rear seat hooks and belt runners £5 the lot
Cambelt cover x3 £5 each
Rear bumper arch spats £5 pair
Seat runner cover £5 all 3
Rad tray £5
Carbon canisters £10 each
Rear light £5
Clear indicator
Washer bottle £10
Wheel spacers x4 10mm £20 all 4
Engine mounts plus brackets £20
Fuse box £5
Gt fuel rail and TB with top cap £40 the pair
Window seal £10 pair
Scuttle tray seal £5
Door seal (has small cut on join) £5
VW1 calliper carrier £8 pair
Driver glass £5
Fan £5
Wiper motor £15
Door trim £5
Carpet metal holders £8 pair
Font wipers £10 pair
Air vent channels £5 each
Dashboard tray £5
Radio £15
Jack kit x2 £10
Edited by RetroWheels
  • Replies 13
  • Views 708
Alright mate,
Are the larger diameter water hoses in the second pic from a GT? If so I will have all 3, I will need them posted so would be grateful if you could send me a price inc p+p to DD11 3RB.
Boab
How much for
1 x Mirror knobs and gaitor
2 x Plastic suspension caps
2 x Rear arch spats (both sides of car)
All posted to TW19 6BB?
What is the radio boston ? does it have code ? does it work ?
Thank you..
Thank you..
I shall get more info on it tomorrow for you. I'm not sure if it works or not, one polo is completely stripped and the other has had the radio wires chopped off so i cant test it for you..But if you did want it and it didnt work id give you your money back! I do have another radio, bit different looking but i know for a fact that one worked...I try find it in the morning.
Can you do a price on the driver's side dash vent, the radio (doesn't matter if it's coded, I can do them), and the clear indicator, posted please?
Any MK2 grille badges?
The big one may actually be. Its metal yet the mk2f ones aren't. I'll get some sizes sent over soon.
I'll take:
1 rear suspension cap
2 front suspension caps
1 seatbelt cover
Postage to WN7 1LH?
I'm after the rear light and a big blank for the dash.
Any damage or cracks to them?
Do you have the tailgate door card by any chance? Also drivers side front arch has a small length of side bumper trim.
Regards James.
i'm after the windscreen washer piping, 2 window winders and the wing mirror caps for inside the car plus the full rear seatbelt set
Hi mate, I'm after the two door window seals in the 8th pic as long as there is no damage or splits. Posted to le12 5lq.
What sort of price can u do them for?
Andy
You still got the wheel spacers?
