Cheap Powerflow exhaust for mk3 (g40)
I have the old powerflow cat-back, single silencer exhaust I need to get rid of.
If someone turns up with £50, it's yours! Pick up from Heywood, Lancs.
Photos:
https://goo.gl/photos/N1vFZCww9TFMuZuf8
Note, this is a one-piece exhaust and the front to back length is 2.6 meters so make sure you turn up in a car big enough to fit it in.
It's the correct bore to fit right onto a g40 downpipe. It's powerflow so it has a stainless silencer & tail pipe and a mild-steel mid section pipe. It has a flexi piece in it which is in good condition. There's no problems with it, no holes etc...
One slight oddity is that it has hangers on it to mount to the rear exhaust mount point but also hang from the rear axle using a rubber mount like this:
http://i.ebayimg.com/00/s/MzAwWDQwMA==/z/5LYAAOSwo8hTmqz9/$_35.JPG
I always found that a bit odd although it did work. If I were to use this again, I'd mount it using a metal strap around the back box onto the standard mounts - look at the pictures of the PPP exhausts in the PPP section to see what I mean.
As I say, cheap exhaust, £50 gets it!
  • Views 370
You'll prob say no, but can you post?
sorry, it's just too big & heavy.
Open to offers on this now though, I need it gone.
I had my engine posted lol, but fair enough you prob don't want the hassle.
I'm sure it'll be possible to post it but it's going to cost more than it's worth.
PM'd
sold!
This item/s has now sold.
