Removing engine bay harness 6n2
hi all,
I need to replace my harness as I am having wiring problems.
They have 2 6n2 at my local scrappy. I can easily disconnect everything in the engine bay but it's the dash part that puts me off.
Is it possible to pull the wiring through without the dash coming off? Obviously I will disconnect everything first but I can't remember if there are factory cable ties etc under there
Thanks guys
  • Views 606
Popular Days
You can i think- the loom plugs into several coloured connectors behind the fusebox.
BUT removing the dash will make this a lot easier. trust me as i have done it. remove the dash!
