Polo 6N Speed and Rev Pin on clocks
Hi All,
I'm trying to work out what pin on the back of the speedo cluster are the speed sensor and the rev gauge pin, can anyone help?
The car is a 1996 1.4 8V (early style clocks)
Any help would be great!
  • Views 6.3k
Pin assignment on dash panel insert post-36925-0-62126400-1436433458_thumb.p
1 - Not assigned
2 - Cooling system low level indicator
3 - Terminal 31, earth
4 - Not assigned
5 - Terminal 31, electronics earth
6 - MFI save switch (memory)
7 - Hall sender / inductive sender exit ( Lilac wire )
8 - Oil pressure switch 1.8 bar
9 - Oil pressure switch 0.3 bar
10 - Terminal 1 / terminal W ( White wire )
11 - Terminal 30 battery positive, clock
12 - Terminal 58b, dash panel insert illumination
13 - Terminal 15, general
14 - Belt
15 - Not assigned
16 - Alternator warning lamp, terminal 61
17 - Not assigned
18 - Twin circuit brakes and handbrake system warning lamp
19 - Ambient temperature sensor, signal
20 - Glow period warning lamp / CAT / check / choke
21 - Fuel gauge
22 - Left turn signal warning lamp
23 - Coolant temperature gauge
24 - Right turn signal warning lamp
25 - Main beam warning lamp
26 - Not assigned
27 - Speed signal from speedometer sender -G22-, electronic speedometer input ( White wire )
28 - Rear fog light
Pin assignment on dash panel insert attachicon.gif6N Early Speedo Connector.png
1 - Not assigned
4 - Not assigned
14 - Belt
15 - Not assigned
17 - Not assigned
21 - Fuel gauge
26 - Not assigned
28 - Rear fog light
Thanks so much for the info Nige :)
I may be being stupid, but I cant see anything on there for the rev's?
The wire on pin 7 should be rpm but when I looked on autodata the pin on the ECU (36) that connects with pin 7 says it's the instrument data line, but pin 9 on the ECU to pin 10 on the speedo is the rpm signal ??
When Idid a dash conversion on one of these I found it was pin 10 that was RPM, don't know why they couldnt say that though haha
Just a quick note on this, I found out what colours were the RPM and the Speedo.
Speed Sensor: White Wire- Pin 27
RPM: Green Wire - Pin 10
