DTC 17550 17558?
Looking at buying a 9n 2002 Polo (for my daughter).
It's got one recorded DTC fault code 17550
Load Calculation Cross Check Lower Limit Exceeded
which I have found
http://wiki.ross-tech.com/wiki/index.php/17550/P1142/004418
and one 17558.
O2 Control (Bank 2) Out of range
What could cause that?
It's 14 16v BBY engine which I fear is drive by wire.
  • Views 5.9k
Now got some freeze frame data. Engine load was very low 6.2% at time of fault.
Erasing the codes - and seeing if they recur.
For better or worse we bought it...
17550 DTC came back on the journey home.
at 65degC
1025 rpm
6mph
Engine load 8.2 %.
MAP 44kPA (0.44 bar)
ShortFt1 0%
LongFt1 -10.2%
Sys1 0L
I'm guessing a vacuum leak. Maybe the brake servo hose 6Q2612041AJ?
Brake servo hose was a tiny bit loose at the servo, but in reasonable condition, even at the one way valve.
Gave it a 1/8th turn on all the fittings and pushed them together, then used carb cleaner spray in the throttle body - when cold, the when idling, then when revved to 2500 - wow that throttle plate drive by wire operation is weird. I suppose the injection pulse lengths can control most fuel air needs at no load. So the cleaner spray managed to stall engine a few times. That gave some random misfire codes
Anyway, erased the codes. Restarted. No more EPC light on dashboard. No more codes after a short drive to reach temperature and upto 60mph.
