G40 Exhaust Valves
Found a set of 4 exhaust valves today in one of my boxes, checked the part numbers and they are G40 specific ones as I thought. Part number ends 611B.
They are sodium filled, have 8mm stems and will fit most MK2/3 1.3 cylinder heads.
In good clean condition, showing a few speckles of rust on the faces from storage.
£40posted ono
Thanks, Will
  • Views 363
Open to offers
I don't suppose you might know if these can be used in the earlier heads do you? IIRC they have 7mm stems, but not sure. Also, do you know the diameter of these?
Also I need the length
