1.9TDI engine pd150
Just to make it clear this is a full engine the only things missing are gearbox and drive shafts everything else is there, turbo injectors manifolds exhaust and inlet, full wiring loom engine and interior, ecu, the ignition barrel and key, etc
1.9tdi engine pd150 removed from an 03 plate Passat. This is a full conversion including wiring, ecu etc the lot, was brought for a project but changed my plans so now for sale it is currently sat on a pallet so collection only or please arrange your own courier
£400
Edited by pascoe92
  • Views 479
Clocks, box and driveshafts also?
I know you have said everything is there, just I have messaged people recently who have similar ads and their idea of a 'complete conversion' is an engine without anciliaries, turbo, injectors with the odd fucked shafts etc.
Apologise when I said everything I meant everything engine wise so all the turbo and injectors and everything is there the only bits that ain't there are gearbox and shafts but everything else is
Edited by pascoe92
