Weitec GT Rear Coilovers - Ibiza MK3, 6n2 & 6K2
These where from the Ibiza Cupra that donated most of its parts to my 20VT caddy van, I used the fronts but these have been sat in the garage for over a year.
They are the GT range so adjustable for height only, a quality product, there is some surface rust on the springs and they need a good clean, the adjusters I haven't tried moving but the front I needed to use a pair of pipe grips on (as no C spanner) so I would rather not do that to these as it chewed up the adjustment collar.
They will clean up and adjust no problem with some soaking and a C spanner as the adjustment rings are plastic. I'm sure these fit other models such as polo but you would need to check for yourself.
Looking for £75ono for these text during working hours 07843272261 as I dont get on here very often - Located in Swindon Wiltshire
WP_20150716_23_32_04_Pro%20-%20Copy_zpsq
Edited by Damian S
  • Views 244
Reduced to £50 plus delivery at cost
