Exhaust Manifold - needed urgently
For mk1 or mk2 engines.
Will happily drive sensible distances to get it.
  • Views 298
'might' have one, will check tomorrow, when i'm sober
Pre-1984 ones are different to post 1984 ones. The later ones use a clamped on single downpipe, the earlier ones use a twin downpipe that's bolted onto the manifold.
I thought the later ones used the twin downpipe like the mk2f's?
Nope, single pipe.
Probably, but the pipes are that thin I'm not sure you'd gain anything.
Just double checked myself and the early ones seem to be a mix of clamps and bolts, mostly bolts on Mk1, clamps on Mk2.
I'm sure I've got a manifold from a 85 coupe s, early solid lifter engine. I'm in York if it's what your after
