VW wiring connectors
Need to get some wiring connectors the sort from the mk2/mk2f, does anyone know anywhere that can supply them?
  • Views 665
Depends which ones. Usually 1,2 and 3 pin ones are available from electrical suppliers but the bigger ones are VW only.
re use the housings , then you can get the pins from alot of sellers , polevolt ,vehicle wiring products , ebay etc
i want the actual housings I know I can get the pins easy
Which ones are you after buddy? I have a good few laying around
If I haven't got them then you would either have to scour the breakers yard or look them up and get them new from the dealers. Usually not that expensive but usually sold per side ie male and female I'd say for a big 10 way one you'd be looking at £5-6 sort of thing.
I'm looking for the 3 pin for the dizzy and 7 pin for the tci unit on the mk2 ignition system wiring
